Disables the encapsulation of locally originated SA messages with multicast data (if available).
| vrname | Specifies the name of the virtual router to which this command applies. If a name is not specified, it is extracted from the current CLI context. |
By default, multicast data packet encapsulation is enabled for locally originated SA messages.
None.
disable msdp data-encapsulation
This command was first available in ExtremeXOS 12.0.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MSDP feature, see the Switch Engine v33.1.1 Licensing Guide document.
